L98 questions
Old Dec 14, 2002 | 10:48 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
L98 questions
Im putting a l98 with 305 heads that have been ported, it will be a straight drive car, with 3.42 rear, daily driven, its a roller block, what kind of cam should i run, and also i want it to have a little rough idle, i dont want smooth idle, and it will also see use at the strip ocassionally, and it will get full length headers and duals in about another month, thanks
Kevin
Old Dec 23, 2002 | 12:29 AM
Kandied91z's Avatar
good luck with the project what are you going to have into it?
Old Dec 23, 2002 | 01:00 AM
Engine: 383, L69
Well if all plans go right, late january early feb, just gotta get some odds and ends, like clutch pedal assembly, console, and a few other misc.
Old Dec 23, 2002 | 03:45 PM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
if you have an l98 why put the 305 heads on there? thats just gonna hinder performance. just mill the l98 heads to boost your compression and port those. which is already 9.5:1 so u dont want it to high or your not gonna last too long.
Old Dec 26, 2002 | 04:44 AM
MdFormula350's Avatar
hey SinthetikIroc read this one thread.
https://www.thirdgen.org/techbb2/sho...=l98+305+heads
Old Dec 26, 2002 | 05:57 AM
Car: Corvette
Engine: 5.7
ive read that before. read these
http://forums.iroczone.com/viewtopic.php?t=4431
http://forums.iroczone.com/viewtopic.php?t=4430
Old Dec 26, 2002 | 01:42 PM
i see..
seems like it can be done however it may not be the route to go sometimes.
Old Dec 26, 2002 | 02:15 PM
Car: Corvette
Engine: 5.7
your better off jus milling 350 heads to a smaller combustion chamber to raise your compression ratio. and spend the money for porting and polishing some 350 heads which will outflow the 305 heads and accept the bigger valves and what not without shrouding the valves and what not.
Old Dec 27, 2002 | 11:44 PM
Hung Start67's Avatar
Heads??
I have to agree 305 heads on a 350 ported or not does not make any sense..Yes they will work but why do it? Port the L98 heads and be way ahead of the ballgame. Just my 2 cents...later
Old Dec 28, 2002 | 02:46 AM
Engine: 383, L69
i didnt recieve the 350 heads and i dont have that much money for a new set at the moment, i gotta use what i got, but sometime this fall i plan on having the money for a good set.
Old Dec 28, 2002 | 05:20 AM
Car: Corvette
Engine: 5.7
Re: Heads??
exactly.
and you can get some 350 heads out of the junkyard for cheap.
i have 2 sets of heads myself that im trying to get rid of. set of 462624 casting and a set of L98s. theres plenty of stock heads out there for cheap. i just saw a pair of camel hump heads go for 25 bucks on ebay. you just have to look.
Old Dec 28, 2002 | 02:52 PM
Engine: 383, L69
thanks for the info, im gonna hold off on the motor a bit, so i can find a little better head.
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 19, 2015 10:07 PM
redmaroz
Aug 16, 2015 11:40 PM
matthew911
Aug 12, 2015 09:38 AM
