84 v8 into a v6 88 rs? what do I need?
Old Dec 16, 2002 | 06:32 AM
thehurtwithin's Avatar
I'm trying to get a list of exactly everything that I will nedd to swap over from a compleate 84 camro (B stlye) to my 88 RS which is set up with a stock V6. I have a good idea for most of what I need and most of it should be in the other car, but I wanted to know if there was a step-by-step book that walks you through it or if someone with the job already under their belt would be so nice to do it. I really appreciate any help I can get, thanks! -Dave
Old Dec 16, 2002 | 07:02 PM
MdFormula350's Avatar
theres alot of info on here, might try to search around..
the biggest things would be making sure you swap the v8 engine mounts on your car, and most likely you need the v8 bell housing to connect the tranny...
not too sure about any books, i never did that kinda swap..
good luck
84, 88, rs, swap, v8
