Broken Crankshaft??
Old Dec 18, 2002 | 08:19 AM
427camaro's Avatar
Car: 05 Nissan Xterra
Engine: 4.0L DOHC
Transmission: 5 Speed Auto w/ OD
Broken Crankshaft??
I was moving the 455 to test fit it yesterday, and almost got it outside and the motor fell due to a bolt not being tight enough. It flattened the oil pan, so now its not rounded. ( The oil pan didn't hit the crank ) The pulley for the crank got dented up, what's the chance the crank is broken? Is there a way to tell?
Old Dec 18, 2002 | 08:46 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Cranks are pretty strong for the most part. You probably just bent the pulley like you said. Try turning it over with a ratchet on the crank bolt and see how it moves. IF it seems to move somewhat freely,(other then compression) then I would say your probably alright.
Old Dec 18, 2002 | 11:00 AM
ede's Avatar
ede
i'd say slim to none for the odd on breaking the crank in the engine duw to the fall. it's pretty well supported and it didn't take a direct hit. couple of my friends tipped over an engine stand with a 360 on it i had just finished. no problem to it and it was still running 15 years later.
Old Dec 19, 2002 | 02:39 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
'Friends' huh?
To me they'd be 'old friends'.
J/K
Old Dec 19, 2002 | 03:52 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
The only part of the crank that would be of concern is the nose. A visual inspection will suffice.
Old Dec 25, 2002 | 12:50 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I would take the pulley off and check for crank runout with a dial indicator, that's the only way to tell for sure if it bent or not.
sheachopper
Jul 31, 2019 11:27 AM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
Reid Fleming
Oct 10, 2015 09:56 PM
mfp189
Sep 27, 2015 09:25 AM
