Engine dress up
Old Dec 21, 2002 | 03:22 AM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Engine dress up
Is there an advantage in getting those nice tall valve covers ?
And is there an air filter (carb) that works better than ...
Whith a 350/air gap/carb ill probably have to get a cowl hood..
At what point do u need breathers on the valve covers?
or cut up a stock one ?
Tnx for responding
Old Dec 21, 2002 | 06:37 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
In most cases, the only advantage that tall valve covers give, is to the seller's bank account. They do nothing whatsoever for the motor itself, and in some cases (where they aren't equipped with the oil drippers for the rockers) they actually harm other things. The only technical reason to downgrade to them is when your rocker gear won't fit under shorter ones.
The usual reason for those breathers on the valve covers, is when you have valve covers as above, and they don't support the PCV system. Another instance of harm produced by inappropriate replacement, this time by eliminating the system that helps keep the oil clean and free of fuel, exhaust, & condensation.
Old Dec 21, 2002 | 12:36 PM
Spectre's Avatar
Engine: 3.0L/183
cool, thx
BADNBLK
Nov 16, 2016 09:12 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
