'81-- '89 engine swap...
Old Dec 31, 2002 | 06:10 PM
NocturnalZ28's Avatar
I'm looking to buy an '89 IROC with a blown up 350... I have an '81 Z28 with a fairly new 350 that I put in a couple of years ago... My question is, would the engine from my '81 be a direct replacement for the 89 IROC?... I plan on reusing all the TPI etc... and equiptment off the '89 and just using the block/heads from my '81 engine.. Will this work without any problems?
Old Jan 1, 2003 | 10:08 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
It's not exactly "direct", but it is doable. The rear main seal type changed between those years, and so did the flex plate. You'll need a 153-tooth unit for '82-'85 3rd gen V8 application.
The intake mount bolt angle changed for the center two bolts on each side. Either elongate the bolt holes in the intake base, or get an '85/'86 or Vette version.
Otherwise, it's just a matter of changing over everything that bolts to the engine. The only other issue is not having too radical of a cam in the '81 engine - TPI isn't known for being too friendly with high overlap cams.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
