does low mount alternator fit on 3rd gen
Old Jan 1, 2003 | 02:24 PM
blown 83's Avatar
Car: camaro
Engine: 8-71 blown 355
Transmission: TH400
Axle/Gears: 9inch 4.30:1
I searched for a while looking to see if someone else had asked the same question but didn't see anything.
My question is if a low mount alternator setup will clear the frame on the drivers side. Most of these setups say in small print that they may not clear on newer cars.
It is for a short water pump smallblock. It sure does clean up the look of the engine with it mounted low. I figured some of you all had tried it already, so how did it go or not go.
Thanks and happy new year.
Old Jan 1, 2003 | 02:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's not the frame that's the problem but the steering box. There's not a lot of room between the block and the steering box for an alternator. Although I've never seen it, I doubt it will work on a third gen.
Older cars either had the steering box mounted back farther (early nova) with the steering linkage behind the crossmember or they have the steering box mounted on the outside of the frame.
Old Jan 1, 2003 | 05:42 PM
ede's Avatar
ede
does on my car, mosroso crank drive pulley and moroso alternator mount. fits low and on the left side of the car/engine. i don't have PS so that helps. cost near or over 200 dollars for the set up.
Old Jan 1, 2003 | 06:58 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
You will really have to look out for the pitman arm. THe brackets tend to rub. Here is a pic on my Monte SS to give you a idea...I had to get some work done to my pitman arm to fit it all together.
Old Jan 1, 2003 | 07:00 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
I found that its is the pitman arm you really have to llok out for...the bracket tends to rub on the pitman. I had to get some modifications done to my pitman arm to allow it to work on the TPI in my Monte SS.
Here is a pic , not sure if it will help you, but will give you the idea. Don't mind the coolant everywhere. I put a hole in my rad.
Old Jan 1, 2003 | 07:02 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
I found that its is the pitman arm you really have to look out for...the bracket tends to rub on the pitman. I had to get some modifications done to my pitman arm to allow it to work on the TPI in my Monte SS.
Oops sorry about the double post.
What the heck!!! Triple post? What's happening here
Attached Thumbnails does low mount alternator fit on 3rd gen-picture-401small.jpg
eightsixseven
Dec 16, 2024 01:50 PM
Jeremys87
Jul 14, 2022 09:08 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
reiderz iroc
Aug 13, 2015 04:57 PM
