swapping 305 to a 350 and have a question
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
i just ordered a new 350 bored .030 with a big cam and other performance stuff. i'm going to use the holley stealth ram for the intake and 24lb injectors. the engine was dynoed with 375 hp @ 6000 rpm and 380 tq @ 3300 rpm. i'm also going with the slp 1 3/4 headers with straight pipes. the only thing i don't have is a custom chip. my question is do i need one for the install or can i put the engine in and put the chip in later. i know it'll decrease preformance but i figured i have to break the engine in before i can see what it can do, so would waiting for the chip be a bad idea or would it be ok for a couple of weeks. thank you for all your help and do you know of any places where i can have someone make me a custom chip. the only place i know of is fastchip.com thanks again
Transmission: 4L80E/4L80E
You might have better luck on the TPI forum.
I have a bud whose highly modified ZZ4 SD TPI would run with the stock chip, but as he tells the story, his wife couldn't get the car up their slightly inclined driveway into the garage with that chip (he didn't have any trouble, though). With a custom chip, she didn't have any problems, and he passed our strict dyno emissions test with a "fast pass" (low emissions, so full test not required).
