Lt1/T56 Swappers--Question
Old Jan 2, 2003 | 06:50 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
For you guys that have done an Lt1 and T56 swap...did you put them in as a unit or did you put in the motor first and then the trans? If you had to put them in seperately, were the trans bolts a PITA? Thanks in advance for advice.
Old Jan 2, 2003 | 07:42 PM
TexasLT1's Avatar
Car: '92 RS
well, it shouldnt be any different than any other tranny combo. The easiest way I found was to drop the engine in, then bolt the bell housing up, then bolt the trans to the bell housing. Hardest part is restabbing the transmission, but its not too difficult.
Old Jan 3, 2003 | 02:35 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
I did mine with it as a whole, MUCH easier IMO.
Old Jan 3, 2003 | 05:46 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I guess I'll try as a whole. I know that is usually the best way, just wasn't sure if it was possible. Thanks guys.
tylerwerrin
May 23, 2013 03:28 PM
BlueZee28
Nov 11, 2012 11:22 PM
Pocket
LSX and LTX Parts
Dec 29, 2011 09:28 AM
vancestrahm
Jun 24, 2010 10:09 PM
