new engine question
Old Jan 13, 2003 | 12:02 PM
chefdan1's Avatar
new engine question
how often do i need to tighten my intake bolts?? just curious
and will 1.6 rockers really make a difference in my engine?? someone told me to change the rockers?? should I?? THANKS
Old Jan 13, 2003 | 01:08 PM
camaro_1983_383's Avatar
the intake bolts, check them i guess, if they loosen up, you will have a vacuum leak or maybe water in your oil. The 1.6 rockers will give you more lift, this means a little more power. if your running a huge cam, the 1.6 rockers might not work, because your heads can handle only so much lift. if you use roller rockers, you will gain power. some companies claim 20 hp gains but it depends on your application.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
