Dropping BBC w/ or w/o headers ??
We are dropping in a Big Block this weekend but I want to know if I should drop it with the headers installed, with them in the car first or just the motor first and the headers afterwards ??? I want this to go as smoothly as possible...
Headers are Hooker Super Comps...
thanks....
thanks....
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Put the headers in first. You'll never get them in once the engine is in the car.
You'll probably have to pull the engine out again anyway after you see where the headers contact the crossmember or body. Don't hook up anything to the engine until you're sure the headers fit.
Car: 87 IROC L98
Some people have had little to no problems. I had to trim the crossmember, a-arm hangers and notch the underside of the front subframe to get mine in.
Hooker SuperComp BBC swap headers are NOT a direct bolt in. They're probably the worst fitting swap headers out there however they're also the cheapest.
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I have listed all the issues I had with my BBC swap on my page at www.koolmeister.com I almost wore out my die grinder
You will have to lay the headers in the engine compartment before setting the motor in.
Miles
You will have to lay the headers in the engine compartment before setting the motor in.Miles
redformula88
Oct 14, 2015 06:08 PM
