Whos rollin Hot Rod style? ECM less, Extras gone
Car: 1991 RS
Engine: 305 TBI
Who has gutted everything from there third gen, and is running a simple 350 (or not so simple) carb setup, or TPI setup? I mean, no computer, no smog equip, no fluid tanks, vacuum lines etc. If you are one of these people, do you use it as a daily driver also? When doing such a swap, what things need to be considered? For carb apps, the fuel pump needs to be changed? Im curious. If you have any pics, please show me.
i have stripped pretty much everything off from mine, ac, comp., smog, etc. Its a daily driver in the summer
although this winter i am putting the computer back in to run the lock up on the converter, but thats it.
Heres a pic
although this winter i am putting the computer back in to run the lock up on the converter, but thats it. Heres a pic
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
mine is empty too, no ecm, no emissions equipment at all and no washer fluid reservoir.
I have a non-cc quadrajet on the original L69 (rebuilt and modded motor). Right now the trans and axle are broken so it is sitting in storage.
I used to drive it in the summer on clear days and the car would be suitable for everyday use except for the washer fluid and premium fuel/bad fuel econ.
ambainb
Apr 25, 2016 09:21 PM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
gixxer92
Sep 1, 2015 04:32 PM
