The old 305 to 350 swap
Old Jan 18, 2003 | 12:55 PM
fanman's Avatar
Hello. I've got an 85 Camaro that I plan on swaping the 305 carbed LG4 for a carbed 350, and have a few questions. I did do a search and didn't find exactly what I was looking for (got some mixed answers).
My motor has the computer controled q-jet, and I think the computer controled timing advance (not too sure). I would like to elimnate all the computer stuff. I know that I'll have to wire a swith for the lock up converter. Will I be able to wire it up as shown here? https://www.thirdgen.org/newdesign/t...ueswitch.shtml If I elminate the ECM wouldn't I also be taking out the ALDL connector? If so how would I wire it up...with one of those kits from Summit or Jegs?
The 350 I plan on putting in, is comming from a late 70's 3/4 ton truck. Will I have to get any thing special for the swap? Will my gauges (well, idiot lights) still work?
When I take the computer and wiring out..is there anything I should be saving? Or should I just junk it all?
Old Jan 18, 2003 | 12:59 PM
pskel350's Avatar
you shouldnt have to get anything special other then a non cc carb and distributer. also, i kept my computer just so it will lock up the torque converter, its easier then wiring up a switch. all your gauges will still work.
Jake_92RS
Jan 28, 2020 10:37 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
