Id Engine
Old Jan 26, 2003 | 08:58 AM
pitzzilla's Avatar
Car: 79 ELKIE
Engine: TPI 305
Id Engine
Hello all
Trying to ID the engine that was giving to me I was told it is a 305 TPI from a camaro can anyone tell me forsure the year and cube of the engine and what car it was probbaly in?
INFO
Back of block GM50LG / 14010201
Front of Block V0617CFA 1F 492418
Heads ?
Throttle 17085051 1545 HUY
Fuel Rail 1585 HUZ
Intake 14081005
Injector 5235047
Also I was given a Rear Disc axle with the #s 2 AY C323 1 is this from a camaro? Ratio 2.56 7.5
Are these pieces a good start to speed?:rockon:
Old Jan 26, 2003 | 04:05 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Block #
Tell you what I did... Call up a local Chevy dealership, get the parts dept., and give them the block # and ask them to run it... they should be able to... that's what they did for me, told me what it was, what year it was, and even how much HP it produced from the factory. Hope this helps.
Old Jan 26, 2003 | 04:17 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Go to www.mortec.com. But this will only tell you the size and not much else.
Old Jan 26, 2003 | 06:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not out of a Camaro, that's for sure. Camaros were assmembled in a plant with code L (Van Nuys, CA), that motor came from a car built in plant F, wherever that is, and whatever kind of cars they built there.
Beyond that, I nave no clue about the motor, other than that www.mortec.com says it's a 80-85 305 block.
2.56 gears to my knowledge were never offered in a Camaro. They did however come in some A & G cars (Cutlass, Monte Carlo, etc.) See if it has the torque arm mounts on it, which will be a huge boss that would accomodate 2 vertical 7" long bolts through it, next to the pinion yoke. If it doesn't have that, it isn't a F car rear.
Old Jan 27, 2003 | 08:06 AM
pitzzilla's Avatar
Car: 79 ELKIE
Engine: TPI 305
WELL I'M GOOING TO HAVE TO DO MORE RESURCH ON THIS ENGINE THANKS FOR THE HELP GUYS
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
