some advice for a 350 carb
Old Jan 30, 2003 | 08:52 AM
TTcamaro's Avatar
how hard will it be to put a 350 carb onto a 84 camaro with a stock v6 engine and what has to be removed or changed?what does egr mean? on a manifold?:hail:
Old Jan 30, 2003 | 09:59 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
trans, mounts, computer (if you use one), wiring, radiator, some other stuff. Exaust Gas Recirculation and yes you need that.
Old Jan 30, 2003 | 10:17 PM
pskel350's Avatar
pretty much everything from the trans forward. even should change the front springs.
If you have emissions testing in FL. then you need egr....if you dont have testing, you dont need it.
theshackle
Sep 17, 2020 08:26 AM
xkingcodex
Feb 12, 2020 07:43 PM
theshackle
Mar 5, 2017 06:37 PM
theurge
Aug 21, 2015 12:46 PM
stalkier
Aug 21, 2015 01:54 AM
