383 vortec question
Old Feb 18, 2003 | 02:40 PM
91tirespin's Avatar
Car: 91 camaro rs
Engine: 355
383 vortec question
I've got a vortec engine out of a z71. I'm planning on rebuilding it to a 383. It has everything on it the fuel injection too. What do I need to do to make the fuel injection support the 383. Around how much would it cost, or would there be a more practical way?
Old Feb 18, 2003 | 03:24 PM
black83z's Avatar
What kind of fuel induction system do you have currently. It would probably be easiest to use that. I believe that z71 motor comes with TBI. You will need a new ECM or PROM burned to match, if you decide to keep the TBI. You will also need larger injectors, 454 injectors are supposed to work well. What you will have to do to make it work will depend largely on what induction system you have now. DO A SEARCH, that is the best way to find out information like this.
matt
Old Feb 18, 2003 | 03:38 PM
91tirespin's Avatar
Car: 91 camaro rs
Engine: 355
its a 98 vortec motor but I'll have to check to find out what type of injection.
Old Feb 18, 2003 | 05:35 PM
black83z's Avatar
If it's stock, the motor is TBI, i meant what kind of induction do you have on your car.
matt
Old Feb 18, 2003 | 05:48 PM
91tirespin's Avatar
Car: 91 camaro rs
Engine: 355
in my car I've got the 305 with stock TBI.
Old Feb 18, 2003 | 07:31 PM
black83z's Avatar
Then it would be fairly easy to retain your TBI, or swap to a carb. You can get similar mileage, with more power potential out of a carb. If you wish to keep your TBI, you will need a new chip/ecm, new injector(s). I would reccomend a carb, but thats up to you. You should try a search for your questions tho. You should also consider reading/posting at both the carb and TBI boards. Good luck, congrats on finding a good free engine.
matt
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
