LT1 into S10???
Old Feb 28, 2003 | 10:42 PM
Anthology83's Avatar
LT1 into S10???
Alright boys, i've got a theoretical question for ya. I've heard of a LT1 fit into a late model S10. What do you think? It's about time for a new project and i think that would be a lot of fun, if it's possible without much fabrication and metal removal. I know you can cram up to a 396 into an early 90's S10, seen that done, ran like an 8.5... I could obtain a 99 S10, 4 cylinder, auto for about 3,000. Do you think i could get the LT1, tranny, and all other needs for 5,500? I've got about 8500 available. Or would you just shrug this off as a joke, let me know all your opinions!!!
... check this out too if you've got a second.. this is kinda what i'm shootin for...never attached a file before so if it doesnt work out, just ignore it.
Old Mar 1, 2003 | 01:13 AM
lankchevy_350's Avatar
im sure u could get it in there.
kolby
Old Mar 1, 2003 | 10:11 AM
1986z28's Avatar
Car: 86 z28, 87 IROC, 88 sc, 93 z28
Engine: LG4, LB9, LO3, LT1
Transmission: 700r4, T5, 700r4, 4L60
Axle/Gears: 3.73, 3.45, 2.73, 3.42
they havent changed from the 80's so sure! I have a good friend that is putting a blown 350 in s-10, not all that hard of a swap and they are hella fast
Old Mar 1, 2003 | 10:14 AM
1986z28's Avatar
I know thats a ls1 but you can get the idea
Old Mar 6, 2003 | 11:59 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I would think you could get the engine and tranny for 5 grand. I've got a link to where you could buy one, but I'll have to post it when I get home in a couple hours.
Old Mar 6, 2003 | 08:54 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
sounds cool, looks cool, but how fast could it possibly be? ive driven a late model sonoma and it was extremly traction limited with lim slip and the stock 4.3.
Old Mar 6, 2003 | 09:32 PM
Momar's Avatar
Well, from what I have seen they are pretty quick. Can upgrade the suspension on them just like any other car. Also you just have a bed back there. If you really wanted you could cut out more for larger wheels, get a cover for the bed and run a fuel cell. I think you could fit a fairly wide tire on them without modification though.
Ben
Old Mar 6, 2003 | 11:02 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Here it is
http://www.tacreationsusa.com/v8.htm
Old Mar 8, 2003 | 08:13 PM
KiLLJ0Y
Guest
Posts: n/a
you really REALLY need to see John Lingenfelters(i cant spell) 01 Sonoma
its an LS1 twinurbo... 750hp...
Old Mar 9, 2003 | 12:46 AM
Toyota Guy's Avatar
Car: 1981 Toyota Supra
Engine: 5M-GE 2.8l DOHC I6
Transmission: 4 speed auto w/OD
I saw a sweet little S10 with a 350 in it at a car show last year. Externally, looked stock, except for the cowl hood and huge rear tires said it ran low 12's, or something like that. It can be done, and has been done. Shouldn't be any more difficult than swapping one into, say, a Toyota pickup.
Old Mar 9, 2003 | 01:06 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yup, 427ci LS1... they had to convert it to 4WD because tracion was such a massive problem. It did 0-60 in something like 3.5 seconds!!
Old Mar 9, 2003 | 07:39 PM
Mark W. Winning's Avatar
Now who would want to put a V8 in a Toyota pickup!
Old Mar 13, 2003 | 10:11 AM
LT1Powered85Z's Avatar
Car: '85 Z28
Engine: 396ci LT1
Axle/Gears: 4th Gen rear with 4.10s/Eaton posi
I am seriously considering this with my '94 S10. I've already got ZR1s on it...so they'd go together well.
Anyone have any, more specific, info regarding putting an LT1 or LS1 into a S10?
I've swapped an LT1 into a 3rd Gen twice...so the mechanics of it aren't difficult for me...but hints/tips always help.
Eric
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
