What do I need?
Old Mar 3, 2003 | 08:38 AM
427camaro's Avatar
Car: 05 Nissan Xterra
Engine: 4.0L DOHC
Transmission: 5 Speed Auto w/ OD
What do I need?
What do I need to wire in my ignition system. I haven't yet got it. I have an HEI distributor? What else doI need? A control box or what?
Old Mar 3, 2003 | 09:04 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Nothing.
All that a non-computerized HEI needs to run is a 12V feed. Of course, if you want your tach to work, you'd need to plug that in too.
Old Mar 3, 2003 | 08:54 PM
427camaro's Avatar
Engine: 4.0L DOHC
So I don't HAVE to have a control box, or module. All I need is the distributor, and coil?
Old Mar 6, 2003 | 06:25 PM
Pontiacman's Avatar
A module is great if you need increased spark strength below 6000 rpm. If you are gona run above that a control box would be needed. If you're engine isn't high powered you don't need either.
Old Mar 6, 2003 | 08:44 PM
ede's Avatar
ede
yeah you have to have a control module, it's inside the distributor
Old Mar 6, 2003 | 09:55 PM
427camaro's Avatar
Engine: 4.0L DOHC
So pretty much, all I need is the distributor and everything inside it, right? Is that all? Thanks!
