Swap Question
Old Mar 19, 2003 | 11:03 AM
kdgreen's Avatar
Swap Question
If I am swapping from TBI to Carb in my 91 RS and cut out all of the engine sensors, If I leave the computer controll in and remove the SES light, will it still lockup my torque convertor as normal? Thanks.
Kevin
Old Mar 19, 2003 | 11:55 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
Re: Swap Question
Kevin
the computer uses the various sensors on the engine together to do a lot of things..one of which is the TC lockup. without all of that hooked up, you will be missing some information needed nto do that. what type of distributor are you using? because as far as i know, the ECM gets its data (as far as engine speed) from the distributor, then used that data to lockup the converter, as well as the data from the vehicle speed sensor (VSS) in the tailshaft of the tranny.
so...my bet is no. but maybe there is a loophole in the system that you can somehow get around.
-Brian
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
