Dist connecting
Dist connecting
Dropped the 350 into the 89 and its all bolted up, next goal is to get it started, which means the fun part, hooking up the dist. the motor is outta an 86 maro with a computer controled carb and such, i DO NOT want anything computerised on this motor (already got the new carb). how do I wire up the dist so it fires when its supposed to, stop when its supposed to and everything in between. i figure that the alt and starter hookup 2 the stock 2.8 harness but if im wrong, feel free 2 correct me.
-Jeff
-Jeff
Car: 1989 pontiac firebird formula
Engine: Currently building a 355
just go get a distributor for a76-78 hei 350 all you need to do is hook up a power wire and the tach wire.
