305 tbi to 350 tbi
Old Mar 26, 2003 | 10:01 AM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
305 tbi to 350 tbi
i have a 92 firebird with a 305tbi in it...its pretty tired. i have purchased a 350tbi out of a 92 3/4 ton 4x4 pickup. its all rebuilt and ready to drop in. do and of you guys think that i will have any problems doing the swap? if so what should i be aware of and how could i possibly avoid those problems?
thanks for your time guys. jeff
Old Mar 26, 2003 | 07:33 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
it should all be the same pyhsically.
what do you plan on doing as far as the throttle body? which one are you using? which injectors?
you may want to get a chip burned to get the most power out of whatever combo you choose.
-brian
Old Mar 26, 2003 | 09:52 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
well, i was thinkin to just use the 305 throttle body but with the 350 injectors. there than that, i was just going to drop it in
Old Mar 27, 2003 | 07:35 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
If I were you, when I did the swap, I would take out all the roller hardware out of the 305 and get another roller cam and put it in the 350.
Tom
Old Mar 27, 2003 | 07:47 AM
Deemax's Avatar
Car: '89 RS Convertible
Engine: 355
If you do a search on this topic, you'll find plenty of info. You'll need the 350 injectors, knock sensor and module. Other than that, its a straight up drop in.
Old Mar 27, 2003 | 09:36 AM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
in that case, everythings a go! i got everything you guys are mentioning i need, i just didnt know what i acctually needed. thanks alot for all your help, ill post how things went in a few days.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
st.evel07
Aug 13, 2015 06:15 PM
