Lt1 T56 Throttle Cable Question.
Old Apr 3, 2003 | 11:39 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
OK...I finally have the Lt1 in and the t56 also. The car was originally carbed and now the throttle cable is too short. I thought I could use one from a '93 but now I'm not sure if that applies to me because of the T56. Is there some safe and secure way to add length to my current setup to reach the throttle body? I've tried searching and can't find anything that way. Thanks in advance.
Old Apr 4, 2003 | 01:56 AM
Drastius's Avatar
Car: 1985 Camaro Z28
Engine: Caprice LT1
I used a throttle cable from a TPI car, it works fine. I'm not sure of any safe/reliable ways to add length.
Old Apr 4, 2003 | 10:42 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I ordered a TPI cable today. Hopefully it works well.
Old Apr 4, 2003 | 03:13 PM
TexasLT1's Avatar
Car: '92 RS
the TPI cable works great, thats what I used when I did my swap from a 305 TBI
Old Apr 8, 2003 | 01:25 PM
bluepastu's Avatar
Car: 87 vert
Trans Am#5, funny u should post this on. I ordered a used 93 throttle cable from hawkins(which i returned today w/ a 10% re-handling fee). The outter cable(the plastic that surrounds the cable itself) is the rigth lenght. But the cable is about 1.5" to long. So I ended up searching thru the junkyard and found a 91 TPI T/A which works best. At first I ordered the 93 thinking that the head on the 91-92 cable would not work. But after reading the web I found the GM throttle body from 93-97 is the same attachment from 91-92(in F and B bodies). Once I installed the 91 cable - all was well.
Old Apr 8, 2003 | 02:58 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Another option (though not the cheapest) is to go with a Lokar braided stainless cable setup..
Old Apr 10, 2003 | 11:53 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
I welded the TB cable attachment plate from a TPI TB on to the LT1 TB shaft and used my original cable. Works great.
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
