help... V6(1986) to V8(1990) trouble
Old Apr 5, 2003 | 12:38 PM
IronRey's Avatar
I got this doner car with a v8... i swapped the engine(with engine wiring harnes and computer)/tranny/rearend... and put in a new fuel pump... unfortunately i cannot get the car firebird to run... it tries to crank... but there is no fuel going to the engine... i can jump the fuel pump to the battery and turn it on... but even then its not getting into the engine...
it might be the inside wiring harness or
the '90 had a chip in the stearing column
or i don't know what
i really need to get this car going before i move... any help is greatly appreciated
feel free to email me or leave me a message
Old Apr 5, 2003 | 07:21 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
ok i had the same problim in my 92. i fixed it. can you hear your fuel pump turn on? in order for your fuel pump to turn on you need to have your oil pressure switch hooked up.
Old Apr 6, 2003 | 05:58 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Vats mabey?
Old Apr 6, 2003 | 05:50 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
no i dont think it is. if it cranks over then your vats isnt the problem. vats disables your starter and fuel injection.
Old Apr 7, 2003 | 01:34 PM
IronRey's Avatar
thanks for the suggestions... i'll try to see if its the oil switch... if you guys get any new ideas let me know
Old Apr 7, 2003 | 04:24 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
You should also makre sure the relay is conducting the right amount of amperage. I had a relay go bad once. Even tough it switched on and off correctly, it did not conduct enough amperage.
fltche1
Apr 15, 2010 09:56 AM
