best vortec intake?
Old Apr 8, 2003 | 05:39 AM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
best vortec intake?
which vortec intake do you all think is best that is equipped with egr?
Old Apr 8, 2003 | 03:02 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Re: best vortec intake?
GMPP and Edelbrock are the only manufacturers I have found that make carb intakes for vortec heads. The Edelbrock Performer is supposed to be superior to the GMPP intake, but I am not sure if the EGR performer is better as well. Just beward that the edelbrock performer for vortec heads is quite tall, over an inch taller than a normal performer intake for standard heads. With a 3" air cleaner with a 2" drop base, performer for vortecs manifold and a performer 600 carb my wing nut scratches the top of my hood when i drive.
Seth
Old Apr 10, 2003 | 01:43 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Re: Re: best vortec intake?
Seth
Wow, I've got a RPM under the hood on my Vortecs with the same air filter setup and the wingnut just barely scuffs the underside of the stock hood as well. Guess the height difference between the Vortec Performer and RPM isn't what I thought it was...
Old Apr 10, 2003 | 04:22 AM
onebadwagon's Avatar
get a super victor, lol, just cut a hole, who needs EGR anyway.
adam
Old Apr 11, 2003 | 11:50 AM
Todds1987iroc's Avatar
The GMPP vortec intake is the same as the Edelbrock RPM intake. I bought one for one of my cars and it came in a GM box with Edelbrock instructions and edelbrock intake stickers. The only thing about the GM one is you pay $50 more for the bowties and GM label cast into the intake. I bought mine when The GM one was the only one out and edelbrock were on national backorder (march,1999).
Old Apr 12, 2003 | 03:31 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The EGR for Vortec heads isn't setup the way your factory intake is. They use a pipe coming off the exhaust manifolds to an adapter with an EGR port.
Another company that makes a Vortec intake can be found at www.enginekits.com
It's about $130.
Old Apr 13, 2003 | 01:38 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
Hotrod did a test on the Vortec headed 383 crate motor GM sells. They saw a 15hp/15 ft-lb improvement just from swapping to a Performer RPM from that GM Vortec intake. I think it is the same as the Performer, not the RPM...
Bubbajones_ya
Jul 6, 2024 08:32 PM
z 28 jari
Sep 14, 2021 10:03 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
86CamaroDan
Sep 29, 2015 10:08 PM
toronto formula
Sep 10, 2015 07:31 AM
