Later model 350 question
Old Apr 20, 2003 | 03:09 PM
indy82z's Avatar
I am debating on purchasing a 350 motor for one of my Pace Cars. It is originally out of a 87 Iroc and was a TPI motor (although I am keeping the carburetor on my car). The car it was originally in had a electric fuel pump and mine has a mechanical fuel pump. I am trying to keep it as close to stock looking as possible and was wondering if I could remove the block off plate and bolt a mechanical fuel pump to this engine??
The block casting number is: 14093638
Thanks a bunch..
Tom
Old Apr 20, 2003 | 04:16 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
you can bolt a fuel pump up to it, but I think you have to change your camshaft. After 1987, I believe the smallblock camshafts no longer had the lobe to drive the mechanical fuel pump. You will need a fuel pump rod as well.
Old Apr 20, 2003 | 06:55 PM
flyway190's Avatar
I dunno if the cam has provisions for it, but make sure the block does first. Pull off the block-off plate and check to see if there's a hole for the fuel pump pushrod. I know some later blocks don't have it, but I don't know which ones.
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
