coil springs
Old Apr 21, 2003 | 08:15 PM
lilpuertorico84's Avatar
coil springs
hey guys i'm planning on putting a 350 in my camaro which originally came with a 2.8 do i have to change coil springs and is it difficult or dangerous thanks ray
Old Apr 21, 2003 | 11:44 PM
firestarter's Avatar
Car: 86' camaro s/c
Engine: 357
Transmission: th350
Yes u will have to change coil springs on the front. Is it difficult? Depends on who's doing it. Is it dangerous? As far as i'm concerned anything u do under the car is dangerous! But with that said, no. changing front springs aren't bad, just make sure your car is properly jacked up and on blocks(jackstands) and u should be good to go.
Old Apr 21, 2003 | 11:52 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
There is an article in the tech section on how to change springs, fairly helpful if you need a warm fuzzy..
Old Apr 22, 2003 | 02:00 PM
coil springs
thanks alot guys:hail:
Old Apr 22, 2003 | 02:16 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
If you get a rental tool to compress the springs going in, be careful with it. Make sure there is someone there helping. I've found that you don't have to compress the springs that are in the car to get them out. Once you have everything loose, just pry them out.
Old Apr 22, 2003 | 02:24 PM
thanks dude
87v6Bird
Jul 1, 2018 04:12 PM
timonator
Sep 17, 2015 06:57 PM
sandman92084
Sep 12, 2015 10:27 PM
Jlanz55
Sep 6, 2015 03:05 PM
