400sbc swap questions
Old Apr 25, 2003 | 10:38 AM
88305tbi's Avatar
Car: 88sc
Engine: 305 for now
Axle/Gears: peg
hey guys, just a coupla questions for anybody who's done the 400 swap:
will it bolt up to a 700r4?
what did you use for knock sensor/ESC?
thanx
Old Apr 25, 2003 | 04:44 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
a 700r4 should bolt up to it. i believe all chevy small blocks have the same bolt pattern(i'm pretty sure).
Old Apr 25, 2003 | 05:24 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I have a 406 in my 86 Iroc and the 700R4 bolts right up.
Old Apr 25, 2003 | 06:30 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Yes the tranny bolts right up, make sure you use a flywheel made for a 400, they are different than a 350, so is the harmonic balancer. If you are planning on using TPI or TBI you will have to extensive mods to get to run well. TPI doesnt support the air flow that a 400 will want unless you go with a ported base, siamesed runners, bigger TB and some other stuff. TBI on the other hand I have no idea but I would guess you'd have to go with a bigger throttle body and injectors and custom prom. The knock sensor will go in the same place.
onyx,
what does your car run? I just took my 400 into the machine shop today. I am happy that the build up is finally starting.
:lala: :lala:
Old Apr 25, 2003 | 06:33 PM
Blackroc86's Avatar
Car: 1986 Iroc
I will be going to the track in the next month or so. On my gtech competition pro is has run a 12.286 @ 115.95 for whatever that is worth.
evilstuie
Jan 9, 2020 08:29 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
