Flexplate
Old May 4, 2003 | 02:38 PM
Uwe 1985-IROC's Avatar
Car: 1985 IROC-Z28
Engine: TPI 350
Transmission: TH700-R4
Flexplate
Hallo guys,
one of the former owners of my car has put an old 305-engine ( build about 1978 I think ) into my IROC. Now I want to install a 350 ( build 1988 ). Whats about the flexplate. I read the archives, and I know that I definitely need a new one. But do I need one with 153 or 168 tooth and can I use my old starter ?
Thanks, Uwe
Old May 4, 2003 | 03:35 PM
PhilM's Avatar
Car: Accepting applications...
if you are talking about an automatic flexplate, you can use either. which is in there now, and why do you need a new one?
Old May 4, 2003 | 03:41 PM
Car: 1985 IROC-Z28
Engine: TPI 350
I think the 1978-engine has a 2-piece seal and the 1988-engine has a 1-piece seal, therefore the flexplates ( it´s a TH700 ) won´t fit ? ( Should have another bolt-pattern ? )
Thanks, Uwe
Old May 4, 2003 | 03:53 PM
StealthElephant's Avatar
Car: 87' Iroc
as far as i know, 1987+ is a 153 tooth flex, while anything before 1987 is a 168 tooth
Old May 4, 2003 | 04:45 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Either size is available for either crankshaft type.
The easiest thing to do, is to determine what you have now, and get the same size one to put on the other motor. Look at the starter; if the 2 bolts are directly next to each other, then it's a 12¾" (153-tooth) flex plate; if the bolts are staggered, such that the one nearer the crank is about 1½" farther toward teh front of the motor, then you have a 14" (168-tooth). Just get a 1-piece design one to match the size you have now.
84LsxZ28
May 17, 2020 02:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
