V6 to V8, just check it out
ok i drove past an old camaro in a yard with weeds all around it and decided maybe i should stop by. just to see if it had anything i could use, and if the lady would be willing to part it out to me. well it's an 84 camaro with the V8 engine, the 5.0L and it's carbed. she said to make her an offer and i said 300 for just the engine and she said i must be crazy, so what is a good offer to make? how hard would this swap be? can i use the same tranny or do i need to get that also? thanks
Maybe she was looking to sell the whole thing, not part it out?
What do you drive now (year, engine, trans, etc)? I know that myself and others have swapped from sixes and could help given some more info. We've also listed the parts/issues that come up during swaps as well.
she said for the right amount she would just give me the entire car cuz she wants it out of her yard. i drive a 1990 3.1l firebird, 700r4 tranny. anything else you need to know?even if i get the whole car, i'm takin the engine out and putting in my bird cuz the body of the maro is just ugly
The main reason I asked what you had now was to find out what transmission you had and how old your car was. You will have to change your transmission. Being a 1990, you'll have an electric fuel pump, so would have to either disable it in favor of a manual pump, or have to use a three port pressure regulator. Something else that you may want to think about is emissions. Is there any sort of testing where you live?
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Buy the whole car. You need more than just the engine to do the swap. You'll need suspension components and other misc hardware.
I hate to be the one to bring this up, but yet another head scratcher...
At what price do you decide it is not worth it for a 305?
note: you don't have to change any suspension parts. Some swap to stiffer front springs, some do not. I, for the record, stuck with my stock springs.
Transmission: 4L80E/4L80E
1) She's right, $300 for just the engine is crazy. Should be $300 for the whole car.
2) '84 drivetrain into a '90 chassis - not a good idea. Too many things that won't "work", and from a technical standpoint, isn't legal, anyway.
Keep your money, let her sell the car to someone else. If you want to do a V8 swap, look for a '90-'92 'Bird donor car that has the engine/induction/transmission combo you want.
P.S.: I always thought 'Birds were ugly.
Agreed with the rest of it though. Looking back, I enjoyed swapping, and learned a lot, but would have gone the more complex route of EFI if doing it again.
Originally posted by MikeS
Ouch. I figured the 'maro comment was due to age taking its toll.
If it's ugly because it's age-worn, then $300 is probably too much.
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
My bird is not ugly, thank you very much.
BumpaD82
Feb 26, 2016 02:57 PM
Numbah-1
Sep 12, 2015 08:57 PM
