305 tpi on 350
Old May 13, 2003 | 10:47 PM
fyrechikyn's Avatar
305 tpi on 350
could i put a tpi setup from a 305 on a 350 ? i can buy a 305 tpi but i would like to know if i should drop it in or put the tpi setup on a 350?
Old May 13, 2003 | 10:52 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
the tpi is the same...
its actually designed around the 305..but gm threw it on the 350 as an afterthought..
Old May 13, 2003 | 11:01 PM
fyrechikyn's Avatar
so theres no difference physicaly. what about in the ecm?would i have to have a chip ?
Old May 14, 2003 | 08:34 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You need a chip, a 350 knock sensor (tuned to the different knock frequency of the different bore diameter), and injectors that will supply the correct amount of fuel for a 350.
The TPI itself is the same.
Old May 14, 2003 | 10:56 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
350's came stock with 22# injectors as opposed to 19#.
Old May 20, 2003 | 11:57 AM
OFFROADFORD4X4's Avatar
Are you sure about that? Just asking because I have always heard that the TPI was originaly designed for, and used on the 350's, in the vettes. As far as I know the vettes had the TPI a year or two before the camaro.
Old May 22, 2003 | 03:29 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Completed that swap two years ago using my old 305 TPI on a 350 with just the items mentioned previous.
Old May 22, 2003 | 09:33 PM
87WS6's Avatar
Just get a different chip and injectors. Then add a new knock sensor and you are in business.
Although to take advantage of the 350 I would recommend porting your plenum and base. Siameasing the runners, and maybe adding better fuel rails.
Or better yet go with a Super-Ram or a Mini-Ram. I know several people on here swear by the Stealthram but I would not choose one because I have heard that they are a pain in the *** to install.
I find that the Super-ram is the choice for maintaining a smog legal car. The Mini-ram however is decently priced and easy to install.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
