Power steering pump interchangeability
Old May 14, 2003 | 11:54 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
The donor pump has two return(maybe) lines..One coming out from the back and one on the side.Can I just plug up one and use the other??ALso one of the plugs of the donor air compressor has one prong as oppose to two..ITs th eone connected to the body not the one close to the pulley.
Daz
Old May 14, 2003 | 03:25 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Hey could you give some more details on the parts? What are they from, and what are they going into?
Old May 15, 2003 | 07:26 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
It came from a newer truck..
Daz
Old May 15, 2003 | 03:10 PM
yeah you should probably be able to plug it and just run two lines. Unless it has a separate reservoir. Does it have the reservoir built in to it?
Glowsock
Jul 24, 2025 03:15 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
86White_T/A305
Aug 17, 2015 12:16 AM
