305 TBI to 350 TBI
Old May 18, 2003 | 09:27 PM
Ryknow86's Avatar
Car: 84 Camaro Z28
Engine: carbed 350
305 TBI to 350 TBI
hey i did a search but i also want to be sure of what im doing when i do this swap. If i get a 350 TBI and swap out the 305 TBI what will i need to change in the car? will i need a new wiring harness or ECM or anything like that? Also will the stock tranny and rearend from an 84 Z28 305 TBI hold up with a 350 with all modded internals such as cams, pistons, etc. and all stock heads, intake and carb for now, until i get enough money to rebuld the whole thing? thanks alot
Old May 19, 2003 | 05:37 AM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
ecm will work but youll need a new chip, youll need a 350 knock sensor, harness will be fine, and the rear if in good shape should do just fine, thats if your doing a 350 tbi. if going to carb youll need a 3 port fuel pressure regulator, a different distributer, im sure im missing something but im sure someone will pickup where i left off.....good luck
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
st.evel07
Aug 13, 2015 06:15 PM
