anoying vacum lines....
Old May 20, 2003 | 08:50 PM
StrokaMota's Avatar
Just built a 383 for my 88 IROC and dropped it in. Got the mini ram manifold from TPIS and am using a TPIS throttle body as well (which is the factory piece machined to 52 mm).
Question....... I know I don't ned all the factory vacume lines, etc...but are any really needed / should be used? I think I can plug them all but what does that do (if anything) to the Idle Air Control Motor and it's functionality? Would I be disabling the IAC by doing this? Would I get an engine light..? Not exactly sure how the IAC works.
Also, what about how the passenger side valve cover that has a hole that is routed right to one of the vacuum fittings on the passenger side of the t-body (the biggest one)? I have aftermarket valve covers with NO holes. I'll need to make my own wholes for PCV, oil filler, etc...for what I need / want? Should I make a hole and connect it to the t-body like the factory setup does? The thing is the Mini Ram manifold does not have a separate port (bottom center where it mates to the manifold - where the upper stock plenum did - factory ran this port directly to and down the runner's own ports & then routed to the lower manifold, etc..). The mini ram is just one solid opening for the t-body so all the separate spots on the factory t-body will all flow to the same wide open opening of the mini ram and right down the intake. I think running that line from the valve cover to the t-body may be senseless.
Thanks in advance for replies.
PS its been 2 1/2 years since I yanked the stock motor so I am really hating these vacume lines etc...:sillylol:
Old May 21, 2003 | 01:23 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
I do not have any experience with the mini ram. The vaccum line going to the IAC does not have anything do with its operation. I believe it is a switched vaccum source. Other than PCV you need to deal with the brake boost and fuel pressure regulator at a bare minimum. You are better off getting a maunal for the vaccum diagram.
I would ditch those valve covers if they do not have previsions for a PCV valve. If you bore the hole you will have big problems because there is no baffle. Stick the PCV valve in there and you will suck oil big time.
Corry
Aug 26, 2001 11:26 PM
rscamaro91
Aug 13, 2001 08:41 PM
Stell1579
Carburetors
Jul 2, 2001 11:25 AM
Mac
Car Audio
Jun 8, 2001 08:51 PM
ArnoldBraker
May 14, 2001 10:45 AM
