350 HO TBI swappers...come on in
Old Jun 10, 2003 | 10:48 PM
Bulldog92's Avatar
Car: '92 Camaro RS
Engine: 350 H.O.
Axle/Gears: 3.73 posi
I've already ordered my 330 HP 350 HO engine, but I wanted to run the other items on my parts lists past you guys before I place my order with Summit Racing. My parts list is located at http://www13.brinkster.com/scbaeb/camaro/project.html, so please take a minute to look it over and let me know if I'm missing anything.
Here are a few questions for starters:
  • I've seen some posts about needing a high-pressure fuel pump, but I haven't found any information about what to order.
  • Do I have the correct knock sensor/ESC module listed? If not, what is the correct part #?
  • Is the high-flow water pump necessary to cool this motor, or will the stock pump be OK?
  • Should I also install poly motor mounts for stability?
  • Do I need an EGR check valve? (JPrevost had it listed on his parts list)
  • I still have tons of research to do regarding programming a new PROM for this combo, so I won't even bother about covering that yet
Old Jun 12, 2003 | 06:12 AM
Bulldog92's Avatar
Car: '92 Camaro RS
Engine: 350 H.O.
TTT
Come on guys...I really need to order these parts this weekend so I can do my swap next Saturday. Anybody?
Old Jun 12, 2003 | 02:33 PM
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
Re: 350 HO TBI swappers...come on in
looks like im buying the same engine as you. i made a thread titled "just got a $3000 loan" i dont know if itll help u at all. im ordering mine today hopefully
Old Jun 12, 2003 | 07:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I didn't fit the description in your subject line, but I looked anyway.
Looks like a pretty good list. I don't know why you would need a high pressure fuel pump, but a higher volume pump may be in order. I don't know if the knock sensor stuff is the right p/n, but if the p/n is correct for the description, it's the right stuff. You shouldn't need a high flow water pump if the cooling system is up to snuff. Poly mounts are pretty good stuff, but not necessary. I don't know anything about an EGR check valve - perhaps PM JPrevost directly.
Don't use the synthetic immediately. If you do the GM-recommended break-in, you can go with synthetic at the last change (I'd recommend AMSOIL, of course).
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
Eric-86sc
Aug 24, 2015 09:01 PM
