V6 to V8 Swap Question
Old Jun 13, 2003 | 10:54 PM
89FRMLA350's Avatar
Engine: None
Transmission: None
I have the motor and all in and I just need to hook tghe battery and distributor up. Heres the problem... The positive battery cable is hooked to the started and whenever i hook the negative to the battery the starter all of a sudden comes on. And Im using the v6 wiring harness. Is theres something I need to do. It acts like the key is in the on position when i touch the negative to the battery. What gives? I need help!!!
Old Jun 13, 2003 | 11:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Make sure the positive battery cable on the starter solenoid isn't touching the small start terminal, or any of those wires down there.
Old Jun 20, 2003 | 02:57 PM
jeffers42's Avatar
Car: 1985 camaro
Engine: 1971 355
Transmission: 5-speed
I also had a bad soliniod
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
