2.8-5.7 dash gauge cluster question
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I have a 1985 2.8 camaro and and planning on the 350 tpi swap soon. I have a donor drivetrain and a lot of time on my hands.
The question I have is about the dash gauges. The 85 camaro had the idiot dash (speedo and gas only) all the rest were idiot lights.
Is there any way to swap over to the v8 dash cluster with working gauges?
I am assuming all I would have to do would be to change the sending units and get a v8 gauge cluster. Is this correct? I can't imagine GM would have two separate wiring harnesses for just the dash would they?
Also I was planning on using the TPI from a 1986 camaro if that makes a difference.
Transmission: 4L80E/4L80E
Re: 2.8-5.7 dash gauge cluster question
I had a tach in the V6 car, but I swapped cluster/dash/harness & all. Removed all doubt.
Does your V6 engine wiring harness have a tach wire on the distributor?
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Not sure if the harness has a tach wire on the distributor but I ddi swap in a tach-ed cluster from another v6 and the tach worked, the voltmeter worked but the oil pressure and water temp do not (wrong senders).
Was it hard to change the wiring harness for the dash? I do not have a donor car so it might be a little difficult to locate, but if necessary can be obtained.
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Pete
Car: '89 Firebird
Engine: 7.0L
The V6 and V8 tach are funtionally the same (even though the displays are different). The tach is calibrated with a single resistor located being the face. Change the resistor and you have a V8 tach. This is how my tach was converted to V8 because I wanted the 6000 rpm redline shown with the V6 cars. A friend of mine had a variable frequency drive and did the work to calibrate my tach. It's dead on from 200 rpm to 8000 rpm
ambainb
Apr 25, 2016 09:21 PM
