Possible?
Old Jul 12, 2003 | 04:42 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Possible?
Ok, I heard something about this on this board awhile back, but with no real info on it, or if its even possible.
I know that a 305 block cannot be punched out to a 4" bore, because you will hit water. BUT, what I heard awhile back is that you can punch it out to 4", even going into water, and then you can just put a sleeve in the bore, like an LS1 or a Diesel block has.
Is this true, or just BS?
Old Jul 12, 2003 | 04:55 PM
ede's Avatar
ede
not sure if you'd actually hit water taking a 305 to 4" but the cylinder walls would be too thin to use. yes you can sleeve just about all if not all blocks. cost would pretty prohibitive to do all 8 holes. something like 40 dollars a sleeve, plus the cost of machine work. sleeves are usually more to repair one damaged hole to save a block. considering how easy it is to find a SBC 350 block i'd look for a new block.
Old Jul 12, 2003 | 08:01 PM
Air_Adam's Avatar
Oh, i'm not looking for a new engine, I have a stout 350 in my car. I just asked outta curiousity.
Old Jul 12, 2003 | 08:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes, like ede said, it's possible, as a theroetical matter; just not the practical thing to do, unless you're racing in a class that requires the original block for the vehicle but doesn't P&G it, and it's not a claimer class
Old Jul 13, 2003 | 09:54 PM
Air_Adam's Avatar
P&G?
Old Jul 13, 2003 | 10:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
How they measure displacement at a race track without a teardown
Old Jul 15, 2003 | 09:02 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
could you go 305 or 350 to a 4.125" bore?
Old Jul 15, 2003 | 09:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
no
at least, not without sleeving it
Old Jul 15, 2003 | 11:12 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
I ment with sleves.
Old Jul 20, 2003 | 03:26 AM
Air_Adam's Avatar
I dont think you can, because you'd be cutting off too much cylinder to have anything left to work with. Thats why GM had to use siamesed bores on the 400.
