400 flywheel
Old Jul 22, 2003 | 10:10 AM
sbchevyz28's Avatar
400 flywheel
does anyone know of a company who makes an aftermarket flywheel for a 400sb. it will need to be the 10.4 size to fit in my t-5 bellhousing.
Old Jul 22, 2003 | 10:30 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Centerforce
Old Jul 22, 2003 | 10:47 AM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
Here's the flywheel I used on my 408 w\ T5 tranny.
Since the 400 SBC is external balanced, to use that flywheel, you must run a balance plate that bolts between the flywheel and the crank. I don't remember what company I got mine from, but a quick search on the net came up with this site. They have one for $15.
Some will say that the "porkchop" (balance plate) is not as good as taking a stock 305 flywheel to a machine shop and having it "unbalanced". I can tell you from experience that I use the plate and have had my engine in excess of 6000 RPM on many occasions with no problems.
Good Luck
Old Jul 22, 2003 | 04:54 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i have that balancing plate aswell. i have had no problems with it.
Old Jul 22, 2003 | 05:08 PM
Howell86IROC's Avatar
Car: IROC-Z/Mercedes/Land Rover
Engine: 358
this $15.00 will work
I am faced with a similar situation? this balancer plate for $15.00 will allow me to mate the 400 flyweel to my 86' T5? what should i use for a starter? If this is true than, i am forever greatful!
Old Jul 22, 2003 | 06:08 PM
Car: 84 camaro Z28
Engine: 434sbc
with the balancing plate, you can use the 305 flywheel. thus you can use the stock style starter.
Old Jul 22, 2003 | 06:17 PM
sbchevyz28's Avatar
thanks for all the helpful information. i have a 305 flywheel, can i use a balance plate on that to mate it to the 400?
Old Jul 22, 2003 | 06:23 PM
Engine: 358
Bless you all!
I get it! the balancer plate allows me to use my stock 305 flywheel! all it is doing is balancing the assembly so i dont have to use the special externally balanced flywheel for the 400. Then the stock starter will most likely bolt up?
Thank you so much, now im back on track with my 400!
Car: 84 camaro Z28
Engine: 434sbc
yes, the plate sandwiches between the crank and the inside of the flywheel. and balances a 305 flywheel to a 400 flywheel.
Old Jul 22, 2003 | 06:26 PM
sbchevyz28's Avatar
is there a plate on that site that wingnut put up, does anyone else have a link they can send me. :hail:
Old Jul 23, 2003 | 08:00 AM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
Yes
FYI, you can't use your stock 305 starter on a 400. 400's have a staggered bolt pattern. I used this aftermarket mini starter with staggered bolt pattern.
Old Jul 23, 2003 | 08:03 AM
sbchevyz28's Avatar
wing nut you are the man!!! ill finally be on the road now soon. thanks a lot!
Old Jul 23, 2003 | 10:24 AM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
your welcome
glad I could help
Old Jul 23, 2003 | 06:30 PM
sbchevyz28's Avatar
i am actually using my stock 305 starter. it bolts right up. i dunno if whoever had the motor before me had a different hole tapped into the block or not, but it worked for me when i had the car runnin, back in january.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
