So we're building the 350 when...
Old Aug 4, 2003 | 10:05 PM
StealthElephant's Avatar
Car: 87' Iroc
We notice that the Protopline Vortecs I bought have NO room to torque the bolts down, I mean, seriously...how the hell do you torque them down? Stud?
Old Aug 4, 2003 | 10:57 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
This may be a stupid question, but are you sure you have the right bolts?
Old Aug 5, 2003 | 05:15 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
ALOT of heads will have that problem. It's mostly related to the springs. The larger the springs, the less room there is in between them for bolt heads.
Use washer-head bolts with a smaller 12-point drive, such as are available from ARP and others. Studs are not necessary, and can make the problem worse, since it's easier to make a small bolt head that works than a small nut that works.
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
