V6 rear for a 5.0
Old Aug 5, 2003 | 10:15 AM
gearhead998's Avatar
V6 rear for a 5.0
I am buying a 90 firebird with a V6, but it does not run. I am going to take the 305 out of my 85 TA (twisted front end). The motor has about 108,XXX miles. Will the rear end that is behind the 6 hold up?? Thanks for your input.
Old Aug 5, 2003 | 10:47 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
THere is no difference between a 6-cyl and a V8 rear end if they are both 10-bolts.
Old Aug 5, 2003 | 11:30 AM
Thats what i thought. neither have posi. thanks
Old Aug 5, 2003 | 03:32 PM
CaddiBird's Avatar
Car: 89 base 'Bird
Engine: 507ci Caddy
Transmission: BOP TH400
V6's come with a 3:42 gear compared to the V8's 3.23.
Old Aug 5, 2003 | 03:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Some do; some don't. My V8 car came with a 3.73. Some V8 cars come with a 2.73. It varies with the specific engine and year combination, and is subject to special ordering.
Gear ratios vary widely, even from one 6-cyl setup to another, or one V8 to another. Posi is the same way; some get it, some don't (very few 6-cyls do, obviously).
But the rear end model is the same. Same housing, same axles, etc. etc.; same strength and durability in other words. There's no reason you can't use one's rear with the other's motor. In fact, since the 6-cyl cars often have better ratios, sometimes it's cheaper to go to the boneyard and snag a 6-cyl rear to get good gears, than it is to change the gears in a V8 car's rear; especially if the V8 car has drum brakes, and upgrading to discs is not an issue. Which is another option feature that is very rare in 6-cyl cars.
colton_carlson
Mar 8, 2019 12:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
Exxon Limited
Aug 9, 2015 08:13 PM
