will these work with a tbi ?
Old Aug 17, 2003 | 10:42 PM
92 305 BIRD's Avatar
Car: 1992 Firebird
Engine: 305 TBI (LO3)
Transmission: TH-700R4 w/Shift kit
this one http://www.sdpc2000.com/cart.asp?act...d=128&pid=105#
and this one http://www.sdpc2000.com/cart.asp?act...id=128&pid=110
the one says its a great replace ment for a tpi 305. but i have a 305 tbi. and i was just wondering if they will work. thanks
Old Aug 17, 2003 | 11:23 PM
87Formula4bbl's Avatar
Car: '87 Formula
The first one will work no problems, everything will bolt right up, just need a new knock sensor, maybe some chip tuning/bigger injectors for it (I'm not a TBI guy, you'll have to take that up with someone else).
The second one is an older block, having a two-piece rear main. You'd have to buy a new flex plate and get a different intake (old bolt pattern style), and I'm sure there's some other things I'm not thinking of right now. You'd be better off getting the Caprice replacement since you'd have to buy some stuff to make the second one compatable anyhow (like I mentioned, intake, flexplate, etc). Not to mention, the second one is rated at lower HP also. If you swapped in a little better cam into that LO5 you should be happy with it.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
