Head questions.
Old Aug 18, 2003 | 03:34 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Head questions.
What heads and cam would you guys recommend for a 383 rollercam engine? I am keeping the TPI system and changing over to a stealth ram or mini-ram. I have to keep fuel injection due to emissions laws here.
I want nice low end torque and streetablility. I would also like a smooth idle. Nothing to lopey. Just nice and smooth. Fuel economy isn't really an issue. I would also like to keep the engines compression low enough for a supercharger later on.
Old Aug 19, 2003 | 01:42 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
I would reccomend AFR 195's for the heads. They are exspensive, but well worth it. They make a lot of power. For the cam, I'd get a roller version (can't remeber the number off hand) of Comp Cam's XE268, or if that's a little wild for you a XE262.
Old Aug 19, 2003 | 07:36 AM
87WS6's Avatar
Thanks. I figured on some sort of Comp Cams cam. But I wasn't sure on the heads. But as I understand engine building the heads and cam are where the power are made in your buildup.
Also on the heads, I shouldn't have to worry about accessory holes should I?
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
