Any Digital Dash GTA's Running a LT1 ?
Old Aug 19, 2003 | 10:11 PM
N.W. T/A's Avatar
Car: 87 WS6 T/A
Engine: 97 LT1
I need some wiring info. My T/A has a Digital Dash that has a VSS buffer. I'm running a LT1 and T56. Did you have to pull the vss buffer to get the correct PPM signal to the computer? Also what is the PPM on the T56 and the Digital Dash ?
thanks
Old Aug 20, 2003 | 02:30 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
I pretty sure that you do not have to remove the VSS buffer provided it is on the dashboard side. In most installations the VSS sends a signal to the PCM. The PCM then sends a signal to the dash.
I forget the exact details of the PPMS. I once read a post on ls1.com that went into it. If PPM conversion is necessary then you will need one of these products:
check out http://www.dakotadigital.com/products.cfm?Category=122
Hope this helps.
BILL
midge54
Dec 27, 2019 04:14 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Street Lethal
Aug 14, 2015 08:25 PM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
