Head question
Old Aug 20, 2003 | 01:16 AM
2laneblacktop's Avatar
Head question
I'm looking to purchase some new heads, but I'm not real sure on which intake runner size to get. I have a 406, with about 10.1 :1, 230/236 @ .050. I have been running 200cc intake runners with a set of Dart pro 1's, I am probably going to buy another set of the darts, I liked them for the most part, but I am kind of up in the air about whether to get 200 or 215 runners. It has good torque now with the 200's but I didn't know if they mightt be a little small for my application. Any of you engine builders have any advice I would love to hear it. Or if you have had good luck with another set of heads let me know and I will consider them. Also, the car does see considerable amount of track time. I shift the car right around 6K if that helps. Thanks guys
Old Aug 20, 2003 | 07:49 AM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
completely off topic
Just curious, what kind of times are you running with that setup? Also, what intake and fuel delivery are you using? I'm curious because I have a similar engine and was considering a head swap. Currently, I'm running stock castings with larger valves (2.02/1.6).
Old Aug 20, 2003 | 09:24 AM
I'm running a victor jr w/ a 2 inch spacer and a holley 750. The car will run about a 12.70 but I still have some bugs to work out of the suspension and tuning to do with the carb, timing, etc. I just wanted to know what other people thought about the heads, I think I am going to get the 200's again but would like to hear some other opinions.
Old Aug 20, 2003 | 10:21 AM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
Considering you have a relatively mild camshaft, I personally would stay with the 200 cc intake ports. Those larger port heads are designed for higher RPM power. I think you'd be giving up too much low/mid range torque to benefit from the increase in top end power.
Old Aug 20, 2003 | 02:47 PM
daddy33's Avatar
Car: '85 Camaro
what size is the combustion chamber on those heads? if any of you guys deside to get ride of the dart head let me know, im working on a 350 and im looking around for a set of heads, anyways i just wanted to throw that in.....
Old Aug 21, 2003 | 08:27 PM
Well the ones I am going to buy will be 64, but the ones I have are 72.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
