TPI swap......No coil output=No spark???
Old Aug 25, 2003 | 07:23 PM
Wraith's Avatar
I have an older 70's block with 91 heads and a TPI unit from a GTA. The motor is going into a 1972 4x4 Blazer but if any board knows about TPI motors it will be you guys. The problem i'm having is i'm not getting any output from the coil. I am using a painless wiring harness with a seperate coil distributer. I DO have power at the coil and I have check the distributer and it seems fine. If you guys have any thoughts please let me know. Thanks
Old Aug 29, 2003 | 01:36 PM
CaddiBird's Avatar
Car: 89 base 'Bird
Engine: 507ci Caddy
Transmission: BOP TH400
I would check the module, pick-up and coil. If you don't have a multimeter to do it with Autozone will test them for you. Also if you put an ignition box on the truck make sure you have all the wires hooked up correctly.
Azrael91966669
25
Jun 20, 2017 04:04 AM
db057
Aug 22, 2015 08:17 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
Sanjay
Aug 12, 2015 03:41 PM
