2.8 ---> 5.7 swap motor mounts
Old Aug 26, 2003 | 04:04 PM
Phibz's Avatar
Car: 87 Camaro *92 Z28 Clone*
Engine: 350 carb - Alum Dart top end
Transmission: TH400
I am cleaning the bay out and getting ready to drop the newly rebuilt 350 into place. I was wondering on the people who have done this - how did the motor mounts work out? I simply pulled the bolt and left both brackets on. I was told these had to be moved awhile back. Can someone share thier experience?
Mike
Old Aug 26, 2003 | 07:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need to move the halves that mount to the crossmember to the forward-most set of holes. This will require moving the brake line to the back side of the crossmember. It also requires a very fun session of getting a wrench on the nuts that are inside the crossmember (heard recently someone cut a "window" in the front of the crossmember to accomplish this - haven't tried that myself).
You also need the engine halves of the mounts from a 3rd gen V8. Last I heard the dealers no longer have them available.
Frozer!!!
Jan 19, 2024 04:55 PM
Wesly_66
Aug 26, 2015 09:55 PM
jharrison5
Aug 19, 2015 05:53 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
