LT1 guys, what are you using for intake tubing?
Old Aug 30, 2003 | 12:43 PM
BrianI's Avatar
I've seen some people use a TPI set up, others some kind of stock LT1 set up. Wouldn't the TPI tubing be a restriction? What are you using? Pics would be great...
Old Aug 30, 2003 | 10:57 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
Eventually I'll get a K&N setup, but for now I am using the stock TPI tubing, and yes, what a restriction. Its a trans am so it has that plastic box up front....when I rev the motor, I see the thing suck in from the vacume the motor creates! I had to use some 3.5" PVC tubing (With a TON of filing) to make the LT1 MAF fit inline....Oh well, It'll work for now...
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Street Lethal
Aug 14, 2015 08:25 PM
Street Lethal
Aug 12, 2015 11:33 AM
