AC ? 3rd gen LT1 Swap
Old Sep 23, 2003 | 08:29 PM
Deathtrap's Avatar
Car: 1991 Firebird
Engine: 94 to 95 cam conversion 5.7 LT1
Transmission: 700R4 Mega Raptor
Axle/Gears: stock ax with 323 zexel posi
I have swapped my v6 out of my 91 firebird with 94 LT1. Im stumped a little with the ac. I assume i will need to change the system to r134a instead of r12? What all do I need to do to change it over and make it work correctly. I have brand new r12 condensor and evap can would that work or would i need r134a condensor and dryher can? I also see on my pcm it has a ac request signal wire. Does it need to be hooked up and where at? I would most think that it would have to. Any help thanks Thanks for diagrams in the wiring diagram post they helped big time!
Old Sep 24, 2003 | 09:59 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Nice looking swap. From what I understand as long as the r-12 components have been completely evacuated you can use 134a. There is incompatibility in the oil that both systems use.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
