This should be a stickey!
Old Sep 24, 2003 | 08:23 AM
ybaslo1's Avatar
When installing a different engine, or just removing the A/C system and bracket, always remember to plug the top hole on the passengers side of the block next to the mechanical fuel pump inlet. If you do not do this you will have and oil leak and probably replace your front crank seal more than once and recieve multiple headaches. I had just went through this and actually found the leak on accident. I asked everybody that I knew, and they had no suggestion. But then all of a sudden when I told them what it was, they all said "oh yeah, I went through the same thing with mine." *******s!!! Anyways, I thought I would share this and request that it be a sticky.
Maria8
May 22, 2012 01:39 PM
82z28 wrencher
Brakes
May 14, 2012 05:57 PM
chazman
Jan 3, 2012 12:33 PM
bezerker
Jul 10, 2009 03:03 PM
daves12secV6
Feb 21, 2007 09:02 PM
