Adding Ground Straps (LT1 Swap)
Old Oct 11, 2003 | 09:56 PM
N.W. T/A's Avatar
Car: 87 WS6 T/A
Engine: 97 LT1
Hey, I need to add a few ground straps. I need 1 from the engine to the frame , 1 from the engine to the body and 1 from the harness to the engine. Where are some good locations to add them on 87 T/A with a LT1 ? Thanks
Old Oct 14, 2003 | 08:39 AM
TexasLT1's Avatar
Car: '92 RS
The factory ones I know are on the drivers side cylinder head, on the ignition coil bolt, running to the frame rail; on the back of the engine up to the firewall; out of the wiring harness also to the firewall; near the battery directly to the frame.
Old Oct 14, 2003 | 09:02 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I used that flat mesh non-insulated type wire. I ran mine similar to TexasLT1 except I have one on the drivers side head to the motor mount frame bolt.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
