TBI intake to TPI?
Old Oct 20, 2003 | 04:58 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
TBI intake to TPI?
Just founf this on ebay...
http://cgi.ebay.com/ebaymotors/ws/eB...category=36474
Is it possible to take off my TBI intake manifold and instal this TPI setup and have a 305 TPI ?
Old Oct 23, 2003 | 12:27 PM
LUVmy92's Avatar
Car: Camaro
Yes you can but you will need a wiring harness adapter , S&P Performance makes a TBi to TPI adapter. You will also need a custom chip for it also.
Old Oct 23, 2003 | 03:28 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
thas a tad expensive, i got the full tpi setup minus the wiring and chip for 184+shippin
works flawless
Old Oct 23, 2003 | 05:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The runners are worth something. Otherwise, there's a lot of there.
"36 lb injectors". Like those are a good match.
"High Performance ... 48mm throttle body". Rrriiiiighttttt....
Old Oct 26, 2003 | 12:47 PM
KiLLJ0Y
Guest
Posts: n/a
is there a website for that S&P performance place? i have all my TPI parts, minus an old wiring harness. i was wondering if i can just convert my current one.
Old Oct 27, 2003 | 08:18 AM
LUVmy92's Avatar
Car: Camaro
www.hotrodlane.cc is the website and they have some great stuff, alot of it isnt on the site , get a catalog. They have a TBI to TPI wiring harness adapter.
Old Oct 27, 2003 | 02:12 PM
Tonysz's Avatar
You got a good deal but if you want to make mucho power you will have to replace the GM base plate. That is the most restrictive part of the intake and there is not enough material to ported out. The 36 lbs are a litter too big for a 305 or 350 but they will work with a re-programed prom. A set of 24lbs will work better or 30lbs if you have a hot 350ci. I do not remenber if your computer use a MAF sensor, I hope it does, MAF computers can make up for some changes on air flow when you modify the engine with bigger cams, runners, T/B, headers and exhaust systems with out having to reprogram the prom. Try to get a new wire harness because use ones are getting old and their insulation in hard and crack easy. If you have any other question e-mail me to Tonysz383@wideopenwest.com
Tony O.
dutch930
Sep 11, 2015 06:58 AM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
